[postgis-devel] [PostGIS] #211: Inverse transformation borks when fed +nadgrids=@null
PostGIS trac at osgeo.org
Thu Jun 25 14:06:31 PDT 2009
  Reporter:  pramsey  |       Owner:  mcayland
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  postgis 1.3.7
 Component:  postgis  |     Version:  1.3.X
Resolution:           |    Keywords:
Comment (by mcayland):
 Works for me (correcting the small typo in your spatial_ref_sys proj4text
 above):
 pg83 at zeno:~/src/postgis-svn/1.3$ psql -d postgis13
 Welcome to psql 8.3.5, the PostgreSQL interactive terminal.
 Type:  \copyright for distribution terms
        \h for help with SQL commands
        \? for help with psql commands
        \g or terminate with semicolon to execute query
        \q to quit
 postgis13=# insert into spatial_ref_sys (srid, proj4text) values (900913,
 '+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
 +units=m +k=1.0 +nadgrids=@null +no_defs');
 INSERT 0 1
 postgis13=# select
 st_astext(st_transform(st_transform('SRID=4326;POINT(-71.057810000000003
 42.358919999999998)',900913),4326));
          st_astext
  POINT(-71.05781 42.35892)
 (1 row)
 postgis13=# select postgis_full_version();
  POSTGIS="1.3.7SVN" GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.6.1, 21 August
 2008" USE_STATS
 (1 row)
 postgis13=#
 ATB,
 Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/211#comment:2>
