[postgis-devel] [PostGIS] #210: segmentation faults in lwgeom_geos.c:pgis_union_geometry_array
PostGIS trac at osgeo.org
Tue Jun 30 04:55:26 PDT 2009
  Reporter:  dfuhriman  |       Owner:  robe
      Type:  defect     |      Status:  assigned
  Priority:  medium     |   Milestone:  postgis 1.3.7
 Component:  postgis    |     Version:  trunk
Resolution:             |    Keywords:
Comment (by robe):
 Well I compared my torture test before and after the patch and got the
 same exact answer so I assume your desire to get the same answer for non-
 nulls as Paul affirmed is correct.
 Okay good I thought I was imagining things for a moment that I had
 sometimes seen this behavior in 1.3.  So I guess we are just seeing it
 more now because Paul exposed the carpet a little bit and the bugs started
 flying out.  Sorry for the gross graphic, but couldn't resist it. :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/210#comment:26>
