[postgis-devel] [PostGIS] #210: segmentation faults in lwgeom_geos.c:pgis_union_geometry_array
PostGIS trac at osgeo.org
Tue Jun 30 06:56:44 PDT 2009
  Reporter:  dfuhriman  |       Owner:  robe
      Type:  defect     |      Status:  assigned
  Priority:  medium     |   Milestone:  postgis 1.3.7
 Component:  postgis    |     Version:  trunk
Resolution:             |    Keywords:
Comment (by robe):
 Okay so the Geos threw an Error being missing is probably an artifact of
 the new cascading union feature --- should we consider that a bug?  Its
 different behavior from 1.3
 The 1.3 I was testing on is also using GEOS 3.1.1 so I think we can rule
 GEOS out as the culprit.   I'm okay to let this slide if everyone else is.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/210#comment:30>
