[postgis-devel] WKT Raster: Why havingtocompilePostgreSQL&PostGIS first?
Obe, Regina robe.dnd at cityofboston.gov
Mon Mar 2 09:45:19 PST 2009
Pierre,
I cheated on that part as Mark said.  I used my OpenSUSE VM downloaded from http://www.go-mono.com/mono-downloads/download.html (which I use for .NET testing on Linux and just happened to come in handy for postgis development as well)
below to do the autogen stuff and then sftp to my windows desktop with filezilla (though I suppose I could have used a file share, but seemed just as easy to use sftp).
Alternatively for just compiling postgis you can download from the daily svn snapshot and pull out the configure stuff.
Are we going to have an svn snapshot for WKT Raster?  Would be nice if we did.
Hope that helps,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Pierre Racine
Sent: Mon 3/2/2009 11:40 AM
To: PostGIS Development Discussion
Subject: RE: [postgis-devel] WKT Raster: Why havingtocompilePostgreSQL&PostGIS first?
I got GEOS built. Last is PostGIS (and then WKT Raster). I get:
racinep at DESROCHERSA-02 /wktrasterdevel/postgis/trunk
$ ./autogen.sh
/usr/share/aclocal/autoopts.m4:22: warning: underquoted definition of AG_PATH_AUTOOPTS
  run info '(automake)Extending aclocal'
  or see http://sources.redhat.com/automake/automake.html#Extending%20aclocal
Regina already had this problem (http://www.nabble.com/Compile-issues-on-MingW-trunk-td21626492.html) but I don't understand the fix.
Pierre
>From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>bounces at postgis.refractions.net] On Behalf Of Mateusz Loskot
>Sent: 2 mars 2009 10:40
>Subject: RE: [postgis-devel] WKT Raster: Why having tocompilePostgreSQL&PostGIS first?
>Pierre Racine wrote:
>> >> make[4]: Entering directory
>> >> `/wktrasterdevel/postgresql-8.3.5/src/backend/access/common' gcc -O2
>> >> -Wall -Wmissing-prototypes -Wpointer-arith -Winline
>> >> -Wdeclaration-after-statement -Wendif-labels -fno-strict-aliasing
>> >> -fwrapv -I../../../../src/include -I./src/include/port/win32
>> >> -DEXEC_BACKEND  "-I../../../../src/include/port/win32" -
>> DBUILDING_DLL
>> >>  -c -o printtup.o printtup.c In file included from
>> c:/mingw/bin/../lib/gcc/mingw32/3.4.5/../../../../include/security.h:38
>> >>  from ../../../../src/include/libpq/libpq-be.h:50, from
>> >> ../../../../src/include/libpq/libpq.h:21, from printtup.c:19:
>> >> c:/mingw/bin/../lib/gcc/mingw32/3.4.5/../../../../include/sspi.h:60:
>> >> error: syntax error before "SECURITY_STRING"
>> >Googling for the error message confirms this is a known bug and small
>> >fix is explained here:
>> >http://archives.postgresql.org/pgsql-bugs/2009-02/msg00092.php
>> Thanks. However if I can live with a released version of PostgreSQL,
>> I'll be happy.
>> >> So following your suggestion that "There is no need to build
>> >> PostgreSQL" I installed 8.3.6...
>> >> Can I compile Geos with gcc? Or I have to use VC?
>> >GEOS can be build with both. However, I have no idea if you can safely
>> >mix binaries built with MinGW and Visual C++.
>> >> ./configure doesn't seems to be an option.
>> >Why?
>> racinep at DESROCHERSA-02 /wktrasterdevel/geos/trunk
>> $ ./configure
>> sh: ./configure: No such file or directory
>> $ autogen
>> Autogen hang without doing anything...
>You can't use autogen.bat script which is dedicated to bootstrapping for Visual C++.
>You need to use autotools-dedicated one:
>$ ./autogen.sh
>Here it is explained:
>http://trac.osgeo.org/geos/#BuildandInstall
>Mateusz
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090302/409496b1/attachment.html>
