[postgis-devel] WKT Raster:WhyhavingtocompilePostgreSQL&PostGISfirst?
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Tue Mar 3 12:58:06 PST 2009
Even though proj-4.6.1 was built without problem, make install did not
copy it in the /usr tree. Is there a way to see the order in wich it
looks for dll and load them so I could identify what's missing?
>-----Original Message-----
>From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-
>bounces at postgis.refractions.net] On Behalf Of Pierre Racine
>Sent: 3 mars 2009 15:02
>To: PostGIS Development Discussion
>Subject: RE: [postgis-devel] WKT
>>> So I could build everything but now when I try to execute
postgis.sql
>in
>>> a database I get:
>>> ERROR:  could not load library
>>> "C:/msys/1.0/local/pgsql/lib/postgis-1.4.dll": unknown error 126
>>> Any idea?
>>> I compiled postgresql-8.3.6, postgis-svn, geos\trunk and proj-4.6.1
>>You also need to install postgis, not only build it.
>It's done and there. I'm wondering if it just can't find proj4. Is is a
>dll or only a link library.
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
