[postgis-devel] WKTRaster:WhyhavingtocompilePostgreSQL&PostGISfirst?
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Wed Mar 4 06:55:47 PST 2009
He!
I'm happy to say that today, march 4th 2009, I have a PostgreSQL/PostGIS
compiled by myself running on Windows XP! Today is a nice day! (Not like
yestesday :-()
I can now give a try at compiling WKT Raster.
Please never, ho never say again on this mailing list that:
1) You don't have to compile PostgreSQL. You DO have to compile
PostgreSQL in order to compile PostGIS. PostGIS makefiles are highly
dependent on lots of stuff PostgreSQL makes when building that are not
provided in the PostgreSQL installation. Luckily we don't have to
compile Linux to compile PostgreSQL... And to compile ArcGIS to compile
our own ArcGIS Python script...
2) That it takes 20 minutes. The setup is very different on Windows. All
this is a Linux thing and you have to do a lot trial and error to get it
to work on Windows. Took me three days (and two nights).
I promess I will write a compilation procedure if I can convince PostGIS
people to migrate the PostGIS wiki from a 90's wiki to a new millenium
wiki.
Pierre
>-----Original Message-----
>From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-
>bounces at postgis.refractions.net] On Behalf Of Pierre Racine
>Sent: 3 mars 2009 15:58
>To: PostGIS Development Discussion
>Subject: RE: [postgis-devel]
>Even though proj-4.6.1 was built without problem, make install did not
>copy it in the /usr tree. Is there a way to see the order in wich it
>looks for dll and load them so I could identify what's missing?
>>Sent: 3 mars 2009 15:02
>>Subject: RE: [postgis-devel] WKT
>>>> So I could build everything but now when I try to execute
>postgis.sql
>>in
>>>> a database I get:
>>>> ERROR:  could not load library
>>>> "C:/msys/1.0/local/pgsql/lib/postgis-1.4.dll": unknown error 126
>>>> Any idea?
>>>> I compiled postgresql-8.3.6, postgis-svn, geos\trunk and proj-4.6.1
>>>You also need to install postgis, not only build it.
>>It's done and there. I'm wondering if it just can't find proj4. Is is
a
>>dll or only a link library.
>>_______________________________________________
>>postgis-devel mailing list
>>postgis-devel at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-devel
