[postgis-devel] WKT Raster: Bug tracking
Obe, Regina robe.dnd at cityofboston.gov
Fri Mar 6 08:24:13 PST 2009
> Perhaps there is one, personally I've found it very helpful to be able
to link
> from bug reports directly to source code revision/file/line easily,
> as it is possible in Trac (i.e. see http://trac.osgeo.org/geos/).
> Google Code lacks of such feature, so it requires more writing & time
to deal with bugs.
Good point.  At anyrate I would like to see both projects tracked
together  so if we eventually move back to trac for tracking, then both
should be moved at the same time.
Or I suppose since WKTRaster is smaller at this point, it could start
off in trac and then we merge the core PostGIS into that trac.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
