[postgis-devel] Issue 123 in postgis: SQLite output format support for shp2pgsql
codesite-noreply at google.com codesite-noreply at google.com
Mon Mar 9 08:32:48 PDT 2009
Comment #1 on issue 123 by schuyler.erle: SQLite output format support for
shp2pgsql
http://code.google.com/p/postgis/issues/detail?id=123
Please note that the patch was generated against the SVN trunk revision
3813.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
