[postgis-devel] Issue 105 in postgis: pgsql2shp seems to produce incorrect dbase files, problems importing into Gnumeric
codesite-noreply at google.com codesite-noreply at google.com
Mon Mar 9 08:59:56 PDT 2009
Updates:
	Labels: Milestone-1.3.X
Comment #2 on issue 105 by mark.cav... at siriusit.co.uk: pgsql2shp seems to
http://code.google.com/p/postgis/issues/detail?id=105
Changing the tag so all of the 1.3.x and 1.4 issues appear together in the
issue list.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
