[postgis-devel] Issue 103 in postgis: Box3D always gets cast to 2D geometry
codesite-noreply at google.com codesite-noreply at google.com
Mon Mar 9 10:10:44 PDT 2009
Updates:
	Status: WontFix
Comment #1 on issue 103 by mark.cav... at siriusit.co.uk: Box3D always gets
cast to 2D geometry
http://code.google.com/p/postgis/issues/detail?id=103
The issue here is that the cast from BOX3D to geometry only works in 2
dimensions.
Unfortunately the behaviour of the 3rd dimension is not really defined when
casting
from a cube, so we could interpolate the Z coordinates but at the end of
the day that
doesn't really help you at all.
Since there is no well-defined behaviour, we may as well stick with the 2D
conversion
with the Z coordinate set to 0 and mark this as "Won't fix".
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
