[postgis-devel] Issue 96 in postgis: ST_Multi on the new SQL-MM curve types should return a MULTICURVE
codesite-noreply at google.com codesite-noreply at google.com
Mon Mar 9 10:41:55 PDT 2009
Updates:
	Status: Testing
Comment #1 on issue 96 by pwramsey3: ST_Multi on the new SQL-MM curve types
http://code.google.com/p/postgis/issues/detail?id=96
Committed to trunk as of r3817
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
