[postgis-devel] Issue 87 in postgis: Probe_Geometry_Columns does not parse an SRID of -1
codesite-noreply at google.com codesite-noreply at google.com
Mon Mar 9 11:21:04 PDT 2009
Comment #2 on issue 87 by ke... at refractions.net: Probe_Geometry_Columns
http://code.google.com/p/postgis/issues/detail?id=87
It is in trunk ... I can come up with a small patch over the next day or so.
-- Kevin
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
