[postgis-devel] Issue 119 in postgis: ST_AsSVG crashed DBbackendwith large geometries.
Obe, Regina robe.dnd at cityofboston.gov
Mon Mar 9 14:00:45 PDT 2009
I was using OpenSUSE 11 with GEOS 3.1, but I presume the geos doesn't matter for svg.  I'll double-check to make sure I did install and so forth -- could be something wrong with my install.  I'll also try on another pc tomorrow.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Courtin Olivier
Sent: Mon 3/9/2009 4:19 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Issue 119 in postgis: ST_AsSVG crashed DBbackendwith large geometries.
On Mar 9, 2009, at 4:07 PM, Obe, Regina wrote:
Regina,
> Thanks for the compliments.
> Did you commit your change yet?  I don't see any changes in SVN and
> script still crashes.
On my machine everything went well, so i didn't have to commit
anything...
I will check on an another OS to see if i can reproduce this behavour
For information, on what platform did you get this crash ?
Olivier
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090309/4598c977/attachment.html>
