[postgis-devel] Issue 124 in postgis: Missing CompoundCurve parser test when disjoint segments
codesite-noreply at google.com codesite-noreply at google.com
Mon Mar 9 16:32:48 PDT 2009
Updates:
	Status: Testing
Comment #1 on issue 124 by mrk.leslie: Missing CompoundCurve parser test
http://code.google.com/p/postgis/issues/detail?id=124
Fix committed to trunk at r3821.  Is this something that should be ported
back to 1.3?
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
