[postgis-devel] Code sprint notes
Obe, Regina robe.dnd at cityofboston.gov
Mon Mar 9 21:29:31 PDT 2009
Good work Mark.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Mark Leslie
Sent: Mon 3/9/2009 11:43 PM
To: PostGIS Development Discussion
Subject: [postgis-devel] Code sprint notes
I've been trying to take part in principal in the Toronto code sprint,
though my sleeping and working hours mean I'm online when the live
participants are offline.
At any rate, I've been browsing the notes on the wiki and there are a
few points that overlap with what I'm working on.  I've just committed
some parser fixes to handle the CompoundCurve type properly.  I'm
currently working on handling of the sql-mm WKB input and it looks like
there will be no immediate conflict with our current WKB type definitions.
On my todo list but not yet underway is handling the sql-mm z/m as well
as our convensions in the WKT parser and getting the sql-mm st_asbinary
and st_astext outputting properly (though this will likely be a breaking
change, so I haven't sorted it yet).
Mark Leslie
Geospatial Software Architect
LISAsoft
Ph: +61 2 8570 5000 Fax: +61 2 8570 5099 Mob: +61
Suite 112, Jones Bay Wharf 19-21 Pirrama Rd Pyrmont NSW 2009
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090310/db6e5c7f/attachment.html>
