[postgis-devel] Issue 119 in postgis: ST_AsSVGcrashedDBbackendwith large geometries.
Obe, Regina robe.dnd at cityofboston.gov
Tue Mar 10 06:11:40 PDT 2009
> On Mar 10, 2009, at 12:30 AM, Obe, Regina wrote:
>Regina,
>> I retested on my same box (blowing out my whole svn and
>> redownloading from scratch and still run into the same issues.).
>> I'll be able to test on windows aond my other OpenSUSe tomorrow.
> Ok let me know...
Olivier,
I tried this on my windows install and my OpenSUSE 10.3 install and
works okay on those, so just seems to be an issue on my OpenSUSE 11 box
which is running a newer beta GCC.  I'll give your debug suggestions a
try and see if I can make sense of why its happening.
Which GCC did you compile with by the way?
My OpenSUSE 10.3 is running
"PostgreSQL 8.4devel on i686-pc-linux-gnu, compiled by GCC gcc (GCC)
3.4.6 20060404 (Red Hat 3.4.6-10)"  "POSTGIS="1.4.0SVN"
GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.6.0, 21 Dec 2007" USE_STATS"
(so it has an old gcc but then it has a newer PostgreSQL.  ).
My Windows is running
"PostgreSQL 8.3.1, compiled by Visual C++ build 1400"
"POSTGIS="1.4.0SVN" GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.6.1, 21 August
2008" USE_STATS"
(my mingW gcc I compiled PostGIS with iis gcc.exe (GCC) 3.4.5 (mingw
special))
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
