[postgis-devel] Issue 119 in postgis:ST_AsSVGcrashedDBbackendwith large geometries.
Obe, Regina robe.dnd at cityofboston.gov
Tue Mar 10 06:16:59 PDT 2009
> Which GCC did you compile with by the way?
My OpenSUSE 10.3 is running
"PostgreSQL 8.4devel on i686-pc-linux-gnu, compiled by GCC gcc (GCC)
3.4.6 20060404 (Red Hat 3.4.6-10)"  "POSTGIS="1.4.0SVN"
GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.6.0, 21 Dec 2007" USE_STATS"
(so it has an old gcc but then it has a newer PostgreSQL.  ).
Slight correction.  The GCC I compiled PostGIS with on my OpenSUSE 10.3
is
gcc (GCC) 4.2.1 (SUSE Linux)
I'll need to double-check the GCC I used on OpenSUSE 11 to compile
PostGIS, but I'm pretty sure
its newer and probably beta.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
