[postgis-devel] Issue 131 in postgis: Remove GEOS 2.2 support and test for GEOS >= 3.0
codesite-noreply at google.com codesite-noreply at google.com
Tue Mar 10 07:09:59 PDT 2009
Status: Accepted
Owner: mark.cav... at siriusit.co.uk
Labels: Milestone-1.4
New issue 131 by pwramsey3: Remove GEOS 2.2 support and test for GEOS >= 3.0
http://code.google.com/p/postgis/issues/detail?id=131
./configure
make
make install
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
