[postgis-devel] Issue 132 in postgis: Make check should run CUnit
codesite-noreply at google.com codesite-noreply at google.com
Tue Mar 10 07:14:00 PDT 2009
Status: Accepted
Owner: mark.cav... at siriusit.co.uk
Labels: Milestone-1.4
New issue 132 by pwramsey3: Make check should run CUnit
http://code.google.com/p/postgis/issues/detail?id=132
make check
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
