[postgis-devel] Issue 130 in postgis: Fix BdPoly Regression Error
codesite-noreply at google.com codesite-noreply at google.com
Tue Mar 10 07:26:03 PDT 2009
Updates:
	Status: Fixed
Comment #1 on issue 130 by pwramsey3: Fix BdPoly Regression Error
http://code.google.com/p/postgis/issues/detail?id=130
Repaired by making the unparsing ring closure check slightly less strict.
Only closure in x/y is tested.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
