[postgis-devel] Issue 116 in postgis: Hex string representing POLYGON EMPTY crashes postmaster
codesite-noreply at google.com codesite-noreply at google.com
Tue Mar 10 07:30:05 PDT 2009
Updates:
	Status: Fixed
Comment #4 on issue 116 by pwramsey3: Hex string representing POLYGON EMPTY
crashes postmaster
http://code.google.com/p/postgis/issues/detail?id=116
(No comment was entered for this change.)
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
