[postgis-devel] Issue 96 in postgis: ST_Multi on the new SQL-MM curve types should return a MULTICURVE
codesite-noreply at google.com codesite-noreply at google.com
Tue Mar 10 07:38:07 PDT 2009
Updates:
	Status: Fixed
	Owner: pwramsey3
Comment #2 on issue 96 by pwramsey3: ST_Multi on the new SQL-MM curve types
http://code.google.com/p/postgis/issues/detail?id=96
(No comment was entered for this change.)
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
