[postgis-devel] Issue 119 in postgis: ST_AsSVG crashed DB backend with large geometries.
codesite-noreply at google.com codesite-noreply at google.com
Tue Mar 10 08:10:16 PDT 2009
Comment #7 on issue 119 by olivier.courtin: ST_AsSVG crashed DB backend
http://code.google.com/p/postgis/issues/detail?id=119
Mike for 1.3.5 version, you could try with the whole lwgeom_svg.c from
current trunk.
You will at least need to change all new *_release(geom) into pfree_*
syntax.
Another option is to upgrade to new 1.4 (coming soon)
HTH,
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
