[postgis-devel] Remove PDF from Hudson build?
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Tue Mar 10 08:42:06 PDT 2009
Kevin Neufeld wrote:
> Sure, no problem.  That would mean though that the pdf included in the
> tarball wouldn't exactly match the html version, but that's not a big deal.
> -- Kevin
...or of course you can re-run the SVN tarball build as part of the
nightly cron script just before the PDF is generated, so then everything
is synchronised.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
