[postgis-devel] Issue 121 in postgis: update tiger_geocoder to run in PostgreSQL 8.3 (patch attached)
codesite-noreply at google.com codesite-noreply at google.com
Tue Mar 10 12:28:13 PDT 2009
Comment #7 on issue 121 by robe.... at cityofboston.gov: update tiger_geocoder
http://code.google.com/p/postgis/issues/detail?id=121
Okay so I'll go ahead and commit your changes minus line 15 and commit to
1.3 and
1.4.  Mark do you have any objections?  We can then work on the 1.5 to get
it to use
the new 2008.  I'm willing to  put in a bit more time into that effort.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
