[postgis-devel] [WKT Raster] Type of extent column ofRASTER_COLUMNS
Mateusz Loskot Mateusz.Loskot at cadcorp.com
Mon Mar 16 09:47:56 PDT 2009
Frank Warmerdam wrote:
> >> Hi,
> >> I'm wondering why extend column of RASTER_COLUMNS table is of type
> of
> >> GEOMETRY instead of POLYGON (or even BOX2D).
> > I'm taking the idea of BOX2D back, completely forgot it's of POLYGON
> type as well.
> Mateusz,
> I would add that using a polygon has the potential of describing
> irregular image footprints, though this is not supported in the
> "regular_blocking=true" case.
Frank,
Good point.
For now, I've added validation of geometry extent type to accept POLYGONs only
Plus, SRID values of raster and extent are compared.
BTW, I'm a complete noob in the world of PL/PgSQL, so I'd appreciate
if someone fluent in this language could review if the code of AddRasterColumn
function is acceptable/correct/efficient/etc.
Best regards,
Mateusz Loskot
Senior Programmer, Cadcorp
http://www.cadcorp.com
