[postgis-devel] [WKT Raster] Regular blocking restrictions
Mateusz Loskot Mateusz.Loskot at cadcorp.com
Wed Mar 18 08:19:00 PDT 2009
If regular blocking is used, number of constraints are assumed.
They are listed in the specification [1].
I'd like to discuss them in details and ask for comments:
1. All tiles have the same size can be expressed as:
RT_Width(rast) = blocksize_x AND RT_Height(rast) = blocksize_y
2. All tiles must be non-overlapping.
AFAIU, it doesn't mean OGC overlapping (ST_Overlaps) but means
overlapping of extents of all tiles:
SELECT rast && new_rast
Any ideas how to enforce restriction of all tiles appearing on regular block grid?
3. The top-left block must start at the top-left corner of the extent
Assuming, we don't know which is top-left tile/block, the only way to check this
is to do full-scan to find if there is exactly one tile that fits this requirement.
Also, this CHECK seems to be impossible to perform per single INSERT.
Am I right?
4. Portions of tiles that extend behond the raster extent are NODATA
The definition of this restriction is clear, but it's unclear how it
influences some of RT_* functions. For instance, what RT_Width and RT_Height
should return for such tiles? Also, what should be the accumulated width/height
for the whole coverage?
[1] RASTER_COLUMNS Metadata Table
http://www.cef-cfr.ca/index.php?n=Membres.PierreRacineWKTRasterSpecifications
Best regards
Mateusz Loskot
Senior Programmer, Cadcorp
http://www.cadcorp.com
