[postgis-devel] [WKT Raster] Type of extent columnofRASTER_COLUMNS
Mateusz Loskot mateusz at loskot.net
Wed Mar 18 10:59:55 PDT 2009
Paragon Corporation wrote:
>> What you mean as "secondary definitions".
>> Do you mean the overloaded versions of AddRasterColumn?
> Yes that is what I meant.
> So your function body would reduce to
> SELECT AddRasterColumn($1,$2,....);
I see.
> The only annoying thing about the sql function approach is while you can use
> the new declare variable format in the arg list, you can't use it in the
> body.  Or at least not to my knowledge.
OK, thanks for the tip.
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
