[postgis-devel] Re: Q3C
Martin Davis mbdavis at refractions.net
Wed Mar 18 16:16:11 PDT 2009
Hmmm.
How will you handle indexing geometries which cross the dateline (which
includes crossing the poles)?
Paul Ramsey wrote:
> On Wed, Mar 18, 2009 at 2:41 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
>> I'm having a grand time thinking about what the appropriate return
>> value of geography::geometry is :)
> My current thought is an automagical planar projection into an
> appropriate UTM zone or polar stereographic system, based on the
> centroid of the feature. With the extra complication of first looking
> into the projection cache to see what the last projection used was,
> and if it's close enough, using that. Hopefully that way, in the case
> of st_function(geog1, geog2) the two arguments would be both cast into
> the same plane. This would magically allow the geography module to
> make use of all the geometry functions, and only break for really
> large objects that exceed our chosen planar areas.
> P.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
