[postgis-devel] Issue 128 in postgis: Test 1.4 on Solaris
codesite-noreply at google.com codesite-noreply at google.com
Wed Mar 18 16:30:46 PDT 2009
Comment #2 on issue 128 by pwramsey3: Test 1.4 on Solaris
http://code.google.com/p/postgis/issues/detail?id=128
Warnings on Solaris:
lwgeom_estimate.c:855: warning: implicit declaration of function `finite'
lwgeom_gist.c:482: warning: implicit declaration of function `finite'
lwgeom_chip.c:171: warning: long int format, unsigned int arg (arg 4)
lwgeom_geos.c:189: warning: assignment discards qualifiers from pointer
target type
lwgeom_geos.c:228: warning: passing arg 1 of `GEOSGeom_destroy' discards
qualifiers from pointer target
type
lwgeom_geos.c:1095: warning: assignment discards qualifiers from pointer
target type
lwgeom_geos.c:1295: warning: assignment discards qualifiers from pointer
target type
lwgeom_geos.c:1361: warning: initialization discards qualifiers from
pointer target type
lwgeom_geos.c:1495: warning: initialization discards qualifiers from
pointer target type
lwgeom_geos.c:1958: warning: initialization discards qualifiers from
pointer target type
lwgeom_geos.c:1964: warning: initialization discards qualifiers from
pointer target type
lwgeom_geos_prepared.c:53:2: warning: #warning COMPILING PREPARED GEOMETRY
lwgeom_geos_prepared.c:348: warning: assignment discards qualifiers from
pointer target type
lwgeom_geos_prepared.c:381: warning: assignment discards qualifiers from
pointer target type
getopt.c:602: warning: no previous prototype for 'pgis_getopt'
shp2pgsql.c:1352: warning: implicit declaration of function `pgis_getopt'
shp2pgsql.c:1780: warning: passing arg 2 of `iconv' from incompatible
pointer type
pgsql2shp.c:1221: warning: implicit declaration of function `pgis_getopt'
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
