[postgis-devel] Issue 128 in postgis: Test 1.4 on Solaris
codesite-noreply at google.com codesite-noreply at google.com
Wed Mar 18 16:34:51 PDT 2009
Comment #3 on issue 128 by pwramsey3: Test 1.4 on Solaris
http://code.google.com/p/postgis/issues/detail?id=128
Make check fails:
cpp -P -traditional-cpp sql-mm-circularstring_expected.in | grep -v "^$" >
/bin/sh: line 1: cpp: not found
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
