[postgis-devel] Re: Q3C
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Thu Mar 19 02:43:23 PDT 2009
Paul Ramsey wrote:
> My current thought is an automagical planar projection into an
> appropriate UTM zone or polar stereographic system, based on the
> centroid of the feature. With the extra complication of first looking
> into the projection cache to see what the last projection used was,
> and if it's close enough, using that. Hopefully that way, in the case
> of st_function(geog1, geog2) the two arguments would be both cast into
> the same plane. This would magically allow the geography module to
> make use of all the geometry functions, and only break for really
> large objects that exceed our chosen planar areas.
> P.
I must say that I'm not a particular fan of this approach, since I can't
see a way for the user to know what level of accuracy they are getting
for any particular calculation. Plus having some operations randomly
fail because they cross certain points/areas is just going to be a
nightmare to support.
I'd like to see a geography type implemented as a pure angular
calculation set with its own set of related functions derived from
angular arithmetic, plus with its own geodetic indexing scheme. I don't
see the value in just re-hashing what we have with a different type so
we can claim geodetic support, when in fact the reality is very different.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
