[postgis-devel] run_test and PostgreSQL user
Courtin Olivier olivier.courtin at camptocamp.com
Thu Mar 19 06:04:12 PDT 2009
When i play with make check (or only run_test on a single unit test),
i must
launch the process as a postgres system user, something like:
$ sudo su postgres -c "./run_test  a_test"
As i configure pg_hba.conf with postgres user with trust
authentification mode, i don't feel this so practical.
Below a patch to add the ability to specify a PG_USER
in run_test.
Thoughts, reactions ?
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090319/e256d9a2/attachment.obj>
Olivier
