[postgis-devel] Issue 139 in postgis: Default selectivity returned when geometry used for restricted join comes from another table, but accurate when from WKT
codesite-noreply at google.com codesite-noreply at google.com
Thu Mar 19 15:38:21 PDT 2009
Comment #1 on issue 139 by lr1234567: Default selectivity returned when
when from WKT
http://code.google.com/p/postgis/issues/detail?id=139
Just to add my 2 cents.
I tested the above on "POSTGIS="1.3.5" GEOS="3.0.3-CAPI-1.4.2" PROJ="Rel.
4.6.1, 21
August 2008" USE_STATS", PostgreSQL 8.3.7
  The above two return in about the same speed (though plans are very
different --
(the _ST_Contains goes into a nested loop for the non constant geometry )
but the &&
is applied first non-nested and both timings are about the same on my box
92 ms)
But this one even on my 8.3.7 performs really badly (5-6 times worse than
the above
queries - 600 ms) which is closer to what Robert was trying to do) and
bizarrely
doesn't even try to use an index.  So there seems to be a distinct
disadvantage to
doing subselects like this.
SELECT
  count(*)
FROM
  points
  where ST_Contains((SELECT shape FROM shapes WHERE shape_id = 1), point);
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
