[postgis-devel] Issue 119 in postgis: ST_AsSVG crashed DB backend with large geometries.
codesite-noreply at google.com codesite-noreply at google.com
Fri Mar 20 04:11:35 PDT 2009
Comment #10 on issue 119 by robe.... at cityofboston.gov: ST_AsSVG crashed DB
http://code.google.com/p/postgis/issues/detail?id=119
Mark,
Here is my version, postgis_full_version output
PostgreSQL 8.3.1 on i686-pc-linux-gnu, compiled by GCC gcc (SUSE Linux)
4.3.1
20080507 (prerelease) [gcc-4_3-branch revision 135036]
POSTGIS="1.4.0SVN" GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.6.0, 21 Dec 2007"
USE_STATS
Thanks,
Regina
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
