[postgis-devel] Issue 141 in postgis: AsGML multipoint issue on MacOS X
codesite-noreply at google.com codesite-noreply at google.com
Fri Mar 20 04:25:41 PDT 2009
Status: Accepted
Owner: olivier.courtin
Labels: Type-Defect Milestone-1.4 Priority-High OpSys-OSX
New issue 141 by olivier.courtin: AsGML multipoint issue on MacOS X
http://code.google.com/p/postgis/issues/detail?id=141
What steps will reproduce the problem?
make check on mac OS X
(gml unit test)
What is the expected output? What do you see instead?
Right GML output but with extra warning:
+ WARNING:  detected write past chunk end in ExprContext 0x7f0010
in all multipoint output (GML 2 and 3)
Mac OS X 10.5.4
i686-apple-darwin9-gcc-4.0.1 (GCC) 4.0.1 (Apple Inc. build 5465)
(Unit test OK on a linux box)
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
