[postgis-devel] Issue 119 in postgis: ST_AsSVG crashed DB backend with large geometries.
codesite-noreply at google.com codesite-noreply at google.com
Fri Mar 20 09:24:02 PDT 2009
Comment #13 on issue 119 by mark.cav... at siriusit.co.uk: ST_AsSVG crashed DB
http://code.google.com/p/postgis/issues/detail?id=119
Paul,
I see that you have "need upgrade" on your status line.
I vaguely recall that Olivier changed the signature on the ST_AsSVG()
function, so
you need to make sure that you drop the database and create a new one from
postgis.sql to make sure the new signatures take effect.
Regina, have you tried doing this on your setup too?
HTH,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
