[postgis-devel] Issue 119 in postgis: ST_AsSVG crashed DB backend with large geometries.
codesite-noreply at google.com codesite-noreply at google.com
Fri Mar 20 09:36:44 PDT 2009
Comment #14 on issue 119 by pwramsey3: ST_AsSVG crashed DB backend with
large geometries.
http://code.google.com/p/postgis/issues/detail?id=119
I take it back, apparently I was testing against an old version of the
library. When I went to get you a stack trace
against a pristine install, everything worked fine. No problems here as of
r3915.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
