[postgis-devel] Issue 95 in postgis: PostGIS 1.4 documentation update
codesite-noreply at google.com codesite-noreply at google.com
Sat Mar 21 02:38:57 PDT 2009
Comment #15 on issue 95 by mark.cav... at siriusit.co.uk: PostGIS 1.4
http://code.google.com/p/postgis/issues/detail?id=95
Off the top of my head, I don't know as I would have expected that to work.
I suspect
I shall probably be looking at the selectivity code for the new bug over
the next
couple of days, so maybe that will help.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
