[postgis-devel] Issue 119 in postgis: ST_AsSVG crashed DB backend with large geometries.
codesite-noreply at google.com codesite-noreply at google.com
Sat Mar 21 06:07:27 PDT 2009
Comment #15 on issue 119 by robe.... at cityofboston.gov: ST_AsSVG crashed DB
http://code.google.com/p/postgis/issues/detail?id=119
Mark,
I use script that drops the database and rebuilds it isntalling the
generated
postgis.sql script and then runs the torturetest script.  I'll verify to
make sure
it is running the right install script and get back to you on this.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
