[postgis-devel] Issue 142 in postgis: 1.4 snapshot build is broken
codesite-noreply at google.com codesite-noreply at google.com
Sat Mar 21 14:52:02 PDT 2009
Status: Accepted
Owner: robe.... at cityofboston.gov
Labels: Type-Defect Milestone-1.4 Priority-Critical
New issue 142 by robe.... at cityofboston.gov: 1.4 snapshot build is broken
http://code.google.com/p/postgis/issues/detail?id=142
What steps will reproduce the problem?
1. Download postgis-1.4.0SVN.tar.gz from postgis website
2. ./configure
What is the expected output?
config.status: executing libtool commands
sed: can't read ./ltmain.sh: No such file or directory
mv: cannot stat `libtoolT': No such file or directory
cp: cannot stat `libtoolT': No such file or directory
chmod: cannot access `libtool': No such file or directory
What do you see instead?
It should hmm work without error.  Mike first pointed this out in postgis
newsgroup
http://postgis.refractions.net/pipermail/postgis-users/2009-March/023054.html
Please use labels and text to provide additional information.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
