[postgis-devel] Issue 119 in postgis: ST_AsSVG crashed DB backend with large geometries.
codesite-noreply at google.com codesite-noreply at google.com
Sat Mar 21 23:38:36 PDT 2009
Comment #21 on issue 119 by olivier.courtin: ST_AsSVG crashed DB backend
http://code.google.com/p/postgis/issues/detail?id=119
For information this was related to precision handle change (significant
digits versus precision digits).
A static buffer is used before trim trailing zero and wasn't large enough
with full precision datas
The others export functions was also concerned and fixed (GML, GeoJson,
KML) in r3921
GCC with FORTIFY_SOURCE was a so good think to help find this issue !
Greats thanks to Regina and Mark for your help and patience on this one !
Olivier
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
