[postgis-devel] Issue 142 in postgis: 1.4 snapshot build is broken
codesite-noreply at google.com codesite-noreply at google.com
Sun Mar 22 05:22:24 PDT 2009
Comment #6 on issue 142 by mloskot: 1.4 snapshot build is broken
http://code.google.com/p/postgis/issues/detail?id=142
Kevin, at this moment SVN server seems to be not responding, so can't check
now.
However, I have had not experience any problems with building SVN trunk.
So yes, postgis builds for me properly on Linux using automake 1.10.2 and
autoconf
2.63 and libtool 2.2.6.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
