[postgis-devel] Issue 142 in postgis: 1.4 snapshot build is broken
Paul Ramsey pramsey at cleverelephant.ca
Sun Mar 22 14:56:11 PDT 2009
Perhaps the infrastructure move will come sooner than later... I'll
ask osgeo.org SAC if they can have an SVN instance ready for us. And
I'll start my own private fun of figuring out how to extract the bugs
from the tracker.
P
On Sun, Mar 22, 2009 at 1:56 PM, Kevin Neufeld <kneufeld at refractions.net> wrote:
> Argh.  Thanx for the heads up.  Yup, it looks like SVN went down again.  At
> least the web site didn't go down as well.  The reliability of the hosting
> server is definitely getting to be a problem.  Hmmm ... none of the usual
> fixes seem to be working this time.  I'll let you all know when we've been
> able to restore services.
> Thank-you all for your patience.
> -- Kevin
> codesite-noreply at google.com wrote:
>> Comment #7 on issue 142 by mloskot: 1.4 snapshot build is broken
>> http://code.google.com/p/postgis/issues/detail?id=142
>> Trying to connect to SVN, I'm getting this error:
>> mloskot at dog:~/dev/postgis/_svn$ svn co
>> http://svn.refractions.net/postgis/trunk trunk
>> svn: OPTIONS of 'http://svn.refractions.net/postgis/trunk': Could not read
>> status
>> line: Connection reset by peer (http://svn.refractions.net)
>> You received this message because you are listed in the owner
>> or CC fields of this issue, or because you starred this issue.
>> You may adjust your issue notification preferences at:
>> http://code.google.com/hosting/settings
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
