[postgis-devel] Issue 137 in postgis: st_distance, shortestline (, st_maxdistance)
codesite-noreply at google.com codesite-noreply at google.com
Mon Mar 23 14:33:17 PDT 2009
Comment #1 on issue 137 by post... at jordogskog.no: st_distance, shortestline
(, st_maxdistance)
http://code.google.com/p/postgis/issues/detail?id=137
There were a lot of bugs in my first posting. Now everything seems to work
as it
should in my small tests. This patch includes:
1) a new approach to st_distance (and st_dwithin)
2) st_maxdistance that I think seems to work properly
3) st_shortestline a new function that returns a line from the points where
st_distance is measured.
4) st_longestline, the same as shortestline but to the line from
maxdistance.
I have had some problem with my compilation bahaving differnt from time to
time but
noe I think it seems to work.
There is a lot of naming that is just temporary and I don't know what
conventions to
follow.
hope for some feedback
Nicklas Avén
	postgis.patch  29.6 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
