[postgis-devel] Issue 137 in postgis: st_distance, shortestline (, st_maxdistance)
codesite-noreply at google.com codesite-noreply at google.com
Mon Mar 23 14:58:48 PDT 2009
Comment #2 on issue 137 by pwramsey3: st_distance, shortestline (,
st_maxdistance)
http://code.google.com/p/postgis/issues/detail?id=137
Check out the STYLE document at the source root.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
