[postgis-devel] Issue 142 in postgis: 1.4 snapshot build is broken
codesite-noreply at google.com codesite-noreply at google.com
Tue Mar 24 02:36:09 PDT 2009
Comment #10 on issue 142 by mloskot: 1.4 snapshot build is broken
http://code.google.com/p/postgis/issues/detail?id=142
Just for the records and easy track of the discussion, Paul and me, we
tested some
solutions that look promising and Paul improved the autogen.sh script:
http://logs.qgis.org/postgis/%23postgis.2009-03-23.log
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
