[postgis-devel] Issue 142 in postgis: 1.4 snapshot build is broken
codesite-noreply at google.com codesite-noreply at google.com
Tue Mar 24 08:36:11 PDT 2009
Comment #15 on issue 142 by ke... at refractions.net: 1.4 snapshot build is
broken
http://code.google.com/p/postgis/issues/detail?id=142
Correct.  The box that Hudson resides on which autobuilds PostGIS has been
unable to
build a clean checkout since this all began (rev.3924) using the typical:
./autogen.sh
./configure
make
It errors out with:
Running aclocal -I macros
Running autoconf
Now you are ready to run './configure'
./configure: line 1951: syntax error near unexpected token
`build_libtool_libs,'
./configure: line 1951: `    _LT_DECL(build_libtool_libs, enable_shared, 0,'
We've tried numerous versions of libtool and autogen, but nothing seems to
fix this.
-- Kevin
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
