[postgis-devel] [WKT Raster] Regular blocking in gdal2wktraster.py
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Fri Mar 27 11:19:05 PDT 2009
Well, if your application does not support display of overlapping objects then you should not store overlapping tiles in your db... As if your application does not supports tiff then you should probably not store your data in tiff... It is not because some applications do not supports fonctionalities that we most stop developping functionalities. Overlapping rasters exist and they will always exist. Most desktop applications are able to display overlapping rasters. Your application would take for granted (checking first with SELECT regular_blocking FROM raster_columns WHERE name="mycoverage") that tiles are not overlapping.
Pierre
>-----Original Message-----
>From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>bounces at postgis.refractions.net] On Behalf Of Mateusz Loskot
>Sent: 27 mars 2009 14:03
>To: PostGIS Development Discussion
>Subject: RE: [postgis-devel] [WKT Raster] Regular blocking in gdal2wktraster.py
>Pierre Racine wrote:
>> Does applications like Google Earth profit from regular blocking?
>> Why is it better to query for
>> regular blocked tiles in chunks than just querying for tiles with a
>> proper SQL query and display them as independent raster forming a
>> layer? This is the way vector layer works and nobody complains.
>There is coverage composed of two overlapping tiles
>(size of tiles does not matter now):
>(I hope my ASCII-art format is preserved)
>How do you render it in a basic client (desktop, web, whatever)?
>Mateusz Loskot
>Senior Programmer, Cadcorp
>http://www.cadcorp.com
