[postgis-devel] Issue 151 in postgis: 'SRID=26915; POINT(482020.9789850 4984378.)' fails to parse
codesite-noreply at google.com codesite-noreply at google.com
Thu May 7 13:25:01 PDT 2009
Status: New
Owner: ----
New issue 151 by reid at reidster.net: 'SRID=26915;POINT(482020.9789850
http://code.google.com/p/postgis/issues/detail?id=151
** What steps will reproduce the problem?
=> select AsEWKT(GeomFromEWKT('SRID=26915;POINT(482020.9789850 4984378.)'));
(With no line breaks.)
Note the missing "0" after "4984378.". It's indeed a little malformed, but
unambiguous and IMO should be parseable.
** What is the expected output?
                  asewkt
  SRID=26915;POINT(482020.978985 4984378)
(1 row)
** What do you see instead?
ERROR:  parse error - invalid geometry
** What version of the product are you using? On what operating system?
                         postgis_full_version
  POSTGIS="1.3.5" GEOS="3.0.3-CAPI-1.4.2" PROJ="Rel. 4.6.0, 21 Dec 2007"
USE_STATS
Thanks!
Reid
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
